Car won't start. HELP!!!
Old Feb 17, 2007 | 08:17 PM
algws6's Avatar
Default Car won't start. HELP!!!
i was doing some dyno tuning today and while i was writing my pcm, my laptop froze and the car (vette) showed it was overheated and went into reduced engine power mode. i tried rerwritng the computer but on step "4" in hp tuners it says "failed". now the car won't even start. here are the codes:
[Convenience] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Unknown] U1255 - Class 2 Communication Malfunction (History) (Immature)
[Convenience] B2282 - Unknown (History) (Immature)
[Convenience] B2283 - Unknown (History) (Immature)
[Convenience] B2286 - Unknown (History) (Immature)
[Convenience] B2287 - Unknown (History) (Immature)
[Convenience] B2284 - Unknown (History) (Immature)
[Convenience] B2285 - Unknown (History) (Immature)
[Convenience] B2262 - Unknown (History) (Immature)
[Convenience] B2263 - Unknown (History) (Immature)
[Convenience] B2264 - Unknown (History) (Immature)
[Convenience] B2265 - Unknown (History) (Immature)
[Convenience] U1255 - Class 2 Communication Malfunction (History) (Immature)
[Convenience] U1064 - Loss of Communications with DIM (History) (Immature)
[Convenience] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Convenience] U1096 - Loss of Communications with IPC (History) (Immature)
im thinking i need to get my computer reflased. can anyone tell me what happen?
Old Feb 17, 2007 | 09:03 PM
foff667's Avatar
LS1TECH Sponsor
very important...were you doing a write entire or write calibration only?
Old Feb 17, 2007 | 09:50 PM
algws6's Avatar
write calibration only.
Old Feb 17, 2007 | 09:58 PM
foff667's Avatar
LS1TECH Sponsor
you should be able to still recover it follow the steps at the bottom
http://www.hptuners.com/help/vcm_edi...menu_write.htm
Old Feb 17, 2007 | 10:08 PM
SScam68's Avatar
Did you change your underwear yet?
Old Feb 17, 2007 | 10:12 PM
algws6's Avatar
i tried writing it again and it said the same thing. should i try the "write entire"?
Old Feb 17, 2007 | 10:48 PM
algws6's Avatar
not until i find out what the **** is going on with my car. drive down and help me figure this bitch out!
Old Feb 17, 2007 | 10:54 PM
foff667's Avatar
LS1TECH Sponsor
If you havent already send an email with a link to this thread to support @ hptuners dot com.
Old Feb 17, 2007 | 11:05 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Before you completely freak out, put the battery on charge for a while, then retry to flash the computer. I tuned a SS Silverado once that was so voltage sensitive that I had to unhook power to the stereo for it to take a flash. The Eclipse head unit, even when turned off, would do something, then the flash would fail.
Old Feb 18, 2007 | 09:08 AM
algws6's Avatar
thanks. i already sent an email to hp. if all else fails a buddy said he can bring his tech 2 home and i will completely flash the computer and start from scratch.
