How much is too rich?
Old Feb 18, 2007 | 05:46 PM
1320FEVER's Avatar
Default How much is too rich?
Well, I got my LC-1 hooked up and it works. Woohoo!
But it reads 10.1:1 AFR. Sound too rich to me. Any thoughts on what is considered too rich? And how much power do you think I'll gain by leaning it up to say..12.5:1? The engine is a 408.
Old Feb 18, 2007 | 06:07 PM
yobabiesdaddy2001's Avatar
Definatly rich , too rich. 12.5 is a safe power range for power without dyno capablities.
Old Feb 18, 2007 | 06:10 PM
slow's Avatar
richer than your commanded airfuel ratio at the time.
for a NA vehice, I see no reason to be richer than 12.5
Ryan
Old Feb 18, 2007 | 06:53 PM
1320FEVER's Avatar
Just took it for a test drive. Idling it sat at about 19-20:1. Cruising down the road it was about 14.5-15:1. And when I nailed it, it went all the way down to 10.6:1. Too rich. I am running a 150 shot (wet) although I have not sprayed this new motor yet. It still sounds way to rich even for nitrous. Guess I need to talk to my tuner...
Old Feb 18, 2007 | 08:15 PM
I dont think it should be idling at 19-20:1 that is kind of lean or uhhh very lean. Do you have a tuner program your self?
Old Feb 18, 2007 | 09:13 PM
1320FEVER's Avatar
No sir. I am thinking about getting hptuners though. It seems that you can't trust anyone to spend the time and get it right (Except yourself, because you care about your vehicle and its performance 100x more than anyone else.)
Back to the LC-1,
I am wondering if my Lc-1 needs recalibrating. If true, that would make the WOT VERY rich. Any thoughts on that? Am I just running too lean at idle? Or is it just my LC-1 need recalibrating?
Old Feb 18, 2007 | 09:39 PM
edcmat-l1's Avatar
Is it cammed? Does it lope? If so you cant really trust the wideband reading at idle. If its a smooth idle motor, well, then its way too lean at idle.
BTW 10.5:1 A/F is way too rich. I would verify all your radings with another wideband. Take it to a dyno maybe?
Old Feb 18, 2007 | 09:45 PM
stone4779's Avatar
Did you hook up your LC-1 to your laptop and set it up using the LMProgrammer software?
What kind of gauge are you using?
If the outputs arent programmed it will read fawked up..
Old Feb 18, 2007 | 09:47 PM
1320FEVER's Avatar
Yes, its cammed. 249/244 on a 114+4.
Thats what I was just planning to do, verify the calibration with another wideband.
Old Feb 18, 2007 | 09:49 PM
1320FEVER's Avatar
No, unfortunately I don't have a laptop. Need to get one of those soon...
As far as the gauge, it is the dynotune freebie that they gave away with the LC-1.
Thats probably it though...I'll see if I can borrow a laptop from work tomorrow. Thanks guys..
Old Feb 18, 2007 | 10:00 PM
Doc's Avatar
Doc
Your biggest challenge with that setup is going to be that 98 OS. It can ~work~, like settling for DOS when you could run XP?!? That setup is begging for a Road Runner and RTACS.
Old Feb 18, 2007 | 10:05 PM
edcmat-l1's Avatar
Roadrunner and rtacs would be nice, but not needed. Its definately tunable...
With a 114 LSA it ought to idle pretty nice
Old Feb 18, 2007 | 10:12 PM
1320FEVER's Avatar
Oh yeah, I forgot to mention that the current tune is an open loop tune.
Old Feb 18, 2007 | 10:16 PM
edcmat-l1's Avatar
Why? I could see open loop idle, but I wouldnt think it needs to be open loop tuned....Not that cam.
Do you know what the idle vacuum is?
Old Feb 18, 2007 | 10:19 PM
1320FEVER's Avatar
No, how do I find this out? I had a shop tune it, so I don't know the specifics other than it is an open loop tune.
Old Feb 18, 2007 | 10:24 PM
1320FEVER's Avatar
Here is the car idling just in case you wanted to hear it...
98 Trans Am Idle
Old Feb 18, 2007 | 10:26 PM
edcmat-l1's Avatar
You would need to scan it. How hard does it lope? What RPM does it idle at? That will tell you a little bit. Even with the 240+ duration, with the 114 LSA it should be fairly smooth.
Yeah, that chops pretty hard. It dont sound like a 114. I see why its an open loop tune. Dont trust the wideband at idle. It sees way too much oxygen. Thats also why you cant make it idle in closed loop. It really screws with the 02s. You should be able to make it run in closed loop, just have to make it idle in open. She sounds real nice, tho...
Old Feb 18, 2007 | 10:29 PM
1320FEVER's Avatar
I think its idling about 1100.
I posted a link to the idle in the post above yours..
Old Feb 18, 2007 | 10:34 PM
edcmat-l1's Avatar
going to bed. check back in the am. Feel free to pm if you want. I've tuned some nasty (LS) cams
Old Feb 18, 2007 | 10:40 PM
Doc's Avatar
Doc
I don't disagree that it will be "tunable." How fast and to what degree of satisfaction do you want to settle for? RR and RTACS make no excuses and deliver. As a unpaid 98 owner that has the aforementioned products I will attest to their value. My car idles @ ~ 650rpms.
