Throttle-by-wire using F-Body PCM?
Thanks,
-ch
14 - TAN 800 Throttle Actuator Control Serial Data
15 - ORN/BLK 1061 Throttle Actuator Control Serial Data
I believe those positions are not used on the F-body PCM.
You will need a vette pedal and a TAC. See the attached picture. HTH.
I appreciate the help, thanks!
-ch
Just want to be clear about what you're saying:
1) remove plastic cover on top of 80-pin harness plugs
2) Poke hole through silicone sealant over desired pins
3) And then....what? Jam a wire in there, or is there some way to solder/crimp the wire in place?
Are pins 14 and 15 the only ones I need?
Thanks!
-ch
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
