Please explain relays to me.
Yesterday, I washed the car under the hood. Just as normal, yea, it sputtered a bit after i drove it later on, but no biggy. Today, put 100+ miles on the car w/ plenty of turning off/ cranking back up w/ no problems. Tonight, i leave the gym and go get some gas and when I go to crank it up, all of the electricals are goin crazy. My guages are moving on their own, interrior lights wont come on and when they do, they're faint, and i hear a damn clicking noise in the dash. We hook up some jumper cables to a friend's car and let it charge, nothing happens. No lights or anything. I took off the cables and hit them together to make sure they worked and they did. I left the cables connected on my car and hit the other side together to make sure sparks from that side as well, it sparked. Got in the car to try again and everything lit up like it would work, turned the key and it all went dead again. Nothing. Now, it just has a clicking noise in the dash. W/ no other options, i locked the car up and left it there for the night. Man, its in a good place, but i still hope nothing happens to it tonight
Same thing pretty much happened when it had 15k miles on it. I washed under the hood and later on, the car went bizzark. Headlights were popping up and down w/out the key even in the ignition and the lights turned off. Sounds coming from the dash, lights blinking. I video taped it and took it to the local dealership and they couldnt do anything b/c by that time, the car was back working fine. They said that unless it was doing it in front of them, they couldnt do anything.
It apparently all has to do w/ relays and tomorrow, if it doesnt fire up, i guess im going to have to get it towed and fixed I hate F'n relays and I hate i cant wash under the hood of my car w/out having to worry if im screwing something up. Its not like i soaked it down, i just rinsed it off.
/rant.
ill) accounts for such widespread crap. From what I've
seen on the schematics there isn't much common feed
and no "main relay".
The symptoms to me describe a power or ground fault
that depresses downstream voltage span, to the point
that relays don't work and when they do, sag the line
even more (here comes in the relay chatter).
I'd look first to battery terminals, clean / tighten, and
then chase down the BAT wire to where it becomes IGN
(keyswitch and maybe some relays) and then the ground
(sheet metal, block and BAT_GND). If you want to check
voltages do it at the battery posts while this is going on
and then move outward, BAT+ - block_gnd, BAT+ -
sheet metal, block_gnd to IGN, chassis sheet to IGN,
and so on. At some point they may show you a low
reading and then you look for what's in between the
good and the bad reading probe-points.
