Primary/Secondary VE table?
Old Feb 28, 2007 | 07:30 AM
brad8266's Avatar
Default Primary/Secondary VE table?
I have a 2000 PCM with both VE tables, if I get rid of the MAF and delete the MAF codes will it still run off the secondary table? I know just getiing rid of the MAf will run it on Sec, i just wasnt sure if deleting the MAf codes out will make a difference.
Im thinking of just ditching the maf since it will be a small choke point with the FAST90. Besides its one less thing to tune as well.
Old Feb 28, 2007 | 08:25 AM
12secSS's Avatar
You will be limited to the Secondary VE table and the Low Octane table, unless you run (for example) a 1-BAR SD OS, like that offered from HPTuners.
Old Feb 28, 2007 | 08:26 AM
brad8266's Avatar
i was just gonna run the stock OS until i decide to upgrade to something like the 1bar OS.
Old Feb 28, 2007 | 09:00 AM
foff667's Avatar
LS1TECH Sponsor
yeah you'll fall to the low res. secondary...also make sure you know what your doing for deleting the codes...if not done properly you'll run into no start issues until its fixed
