Need some help with LT4
Old Mar 5, 2007 | 06:29 PM
jds99camaross's Avatar
Default Need some help with LT4
I just bought a 93 firebird formula with the lt4 kit on it. The car is not tuned and i want to know the best programmer for the lt4 kit. It has lt4 heads, cam, and intake.
Old Mar 6, 2007 | 12:19 AM
Rob's Avatar
Rob
I used to use LT1 Edit. Worked for me way back then.
Old Mar 6, 2007 | 06:14 AM
moehorsepower's Avatar
You cannot use LT1 Edit on a 93, it is not a eprom, you will need a actual chip burner.........
Old Mar 6, 2007 | 09:59 AM
CalCam's Avatar
That's right. The '93 PCM is EPROM based and will require a chip burner. The later cars are EEPROM (Flash) based. You'll still need an editor to modify the file. I use Tunercat's editors and chip burners and adapters from moates.net. A mail order tune is available from a few sources.
Old Mar 6, 2007 | 10:06 AM
daniel6718's Avatar
send it off and get it burned plug it back in and be done...
Old Mar 6, 2007 | 10:08 AM
Fire67's Avatar
Just get ahold of Alvin @ PCMforless. He's their chip burner guy.
Old Mar 6, 2007 | 10:57 AM
Rob's Avatar
Rob
You are right and I knew that Didn't pay attention to it being a 93. Try Ed Wright as he was one of the best LT1 guys back then, probably still is I don't know.
Old Mar 6, 2007 | 06:41 PM
rkinney's Avatar
If you want to get into tuning, get the Autoprom from Moates. You can tune in realtime and datalog simultaneously with TunerPro RT, which comes with it. It also has a built in prom burner. It is a very nice piece of equipment.
