Park/neutral perfect, in gear off
Old Mar 6, 2007 | 03:20 PM
pHEnomIC's Avatar
Default Park/neutral perfect, in gear off
I got my idle perfectly reliable when the car is in neutral on an m6 car. It still wants to die when i have it in a gear and the clutch in. Ve table is spot on. I did raf adjustments by logging a/f error for ECTs then did paste special multiply by percent. I added a few degrees of timing at idle and It came out aweomse. How do i adjust the in gear? i noticed the raf table was zeroed all the way through for the in gear. I switched it to one so i could multiply it by a percent but i cant find a way to log it. Can anyone give me some insight?
Old Mar 6, 2007 | 03:30 PM
SSpdDmon's Avatar
The files I show for M6's cars use the in gear tables and not the park/neutral tables. Why are your in gear tables 0? Can you use a compare feature in HPT so you can see the difference in your tune vs. another tune (ie a stock tune)?
Old Mar 6, 2007 | 06:09 PM
pHEnomIC's Avatar
my bad, i zeroed out the p/n again since it is m6. But for some reason, if i flick the shifter into neutral it behaves differently than if it is in gear and the clutch down. Any way i can fix this?
