Need Help Wiring up Sm-AFR to EFILive V2
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Just have questions on the 4 plug analog jack that plugs into the SM-AFR.
What outlets are you using with EFILive? I am assuming the red wire from the 3.3v outlet to EFIlive and the ground?
Can you confirm?
I am assuming again that the WB and NB do not come into play as I have no guages and use EFILive to moniotr WB activity!
TIA
Can you confirm?
TIA
Don't forget to calibrate the power settings. One of the many things I learned at the class yesterday.
Get a known and measured power source (battery) and calibrate individually each of the V2 inputs.
If you are going to get data, might as well have it accurate.
Perry
Perry
