kr at wot.need tuning input
2% off the timing but still pings. it also pings at cruz sometimes. i do have the pred tune in there and it has made the car quicker but was hoping on some input here to see where i could fix this..
pe, inj slope ,pull more timing ect. thanks
If you still get knock go richer or higher on the voltages (.900 plus)....
I would also venture to guess that you are running lean. If you have your PE table set to your desired AFR and you are at 24* WOT, it's gotta be lean. At that point, you need to start looking at your higher RPM MAP areas on your VE table. Also, if it's pinging under normal load, at what RPM and MAP? If it's at lower RPM's, you might be getting TPS knock, which is basically not real knock. If it's somewhere in you regular powerband, I'd say you need to totally redo your VE table.
Alot of times they will start to ping down low and pull a few degrees and then start adding it back in. Its this lower part of the table that if you take just a couple degrees out, and keep it from pulling any to begin with, you can usually keep more timing in up top.
About 90% of the Predator tunes we see are way too lean at WOT which can be fixed in the PE.
