Tuning
Old Mar 13, 2007 | 04:36 PM
99RebelZ28's Avatar
Default Tuning
I need to get my car tuned after I get the EGR and AIR delted and my headers installed. I have a jet perfomance piece of **** thing in there right now (Installed by previous owner). I need to get rid of that for tuning I believe, so my question is where do I find a stock unit and how much is this going to cost me? Thanks!
Old Mar 13, 2007 | 05:54 PM
SSpdDmon's Avatar
The PCM's in our cars don't use aftermarket chips that have been permanently installed. We have calibrations that are "flashed" in. You can either go to the dealership tomorrow/whenever, shell out a few bucks, and have them reflash the PCM back to stock with a Tech II. Or, when you go to get it tuned, have your tuner flash in a stock file and work from there. That simple...
Old Mar 13, 2007 | 05:57 PM
99RebelZ28's Avatar
Theres actually thing on the passengers side under the hood at the back of the engine bay that says Jet Performance
Old Mar 13, 2007 | 06:42 PM
5_02ls1's Avatar
i think the jet is a module that plugs between the harness and ecu,im not sure though
Old Mar 13, 2007 | 06:54 PM
99RebelZ28's Avatar
"Installation On JET Stage 1 Performance Chip:
Quick and Easy Installation: 1) Locate computer under dash or behind passenger side kick panel. 2) Remove computer access panel. 3) Remove the factory Data chip and replace with the JET Performance Chip......15-19 HP/ 15 ft lbs Torque"
This is what it says on the website, haha those numbers are a joke.
Old Mar 13, 2007 | 07:26 PM
slow's Avatar
The jet performance module is a joke, remove it, and throw it as FAR as you can. Then tune the car with a real flash based tuning tool.
Ryan
Old Mar 14, 2007 | 10:32 AM
99RebelZ28's Avatar
So where do I get the stock part? How much does it cost?
Old May 27, 2007 | 11:55 PM
99RebelZ28's Avatar
I know this thread is old but I really never got an answer, I put on my lts tb and delted the AIR and EGR and its not really running too great. I was looking at the jet thing and it looks like it just sits in between the pcm like you could just pull it out and there isn't a stock part that it replaces.
Old May 28, 2007 | 12:57 AM
Doc's Avatar
Doc
Remove it and replace the connectors on the pcm. Find a local tuner. Put the Jet pipe down.
