Ls2 Autove Tuning With Wideband O2
I'm trying to use the Auto Ve tune feature with efi live on a LS2.
I have my innovate lc1 wide band o2 sensor installed, and can monitor and
recorded data from the selected PID's in the data menu. The
calc.ben_lc11_ls2 will display in the data screen but not on my map.
how do I get this to start counting and displaying cells on my map menu?
While "monitoring" the .pids (Ctrl+M), the maps won't collect data. If you hit Ctrl+Spacebar while monitoring or [F3] once your connected to the vehicle (not monitoring), it will record. [F4] will stop the recording and Ctrl+Spacebar will pause recording.
If you hit [F1], you can read all the shortcuts and how the program works in the instruction manual.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I got it, the problem was that in my map I had it set up to use the M.A.P. sensor in KPA but in my PID's I was using in.hg. Once I change them both to
to in.hg my map started recording
