auto VE problem
when im scanning data it keeps trying to make everything richer than what i have it commanded.... im wanting about a 14.4 idle and its at 13.1-4 right now because i can see it on the lm1... but it keeps giving me a number of 1.2 or 1.3 to multiply that table by...
what am i over looking...... it wants to make the whole table richer throughout all the rpms..... i know im just missing something...
What is your commanded AFR...?
edited cause I miss typed.
I am having that issue now.
If I look at my Lm-1 and EFilive dashboard side by side, the EFI live Lm1 AFR is reading about .5 -.7 higher on average.
I need to change the settings in my EFi live to read the same as the Lm-1.
Still haven't figured it out yet tho.
I tried a suggestion on Efilive's forum and ran .5 or more richer than the LM-1 indicated.
how do i disable that... right now i have my 100-kpa row set to 12.0 AFR and my PE mode set to 11.8..... it almost seems like its trying to bring everything to 11.8 .... im just guessing this by the size of the numbers its giving me to multiply my VE table by...
yes the TPS% is low but i'd like it to be set at about 75% once i get comfortable with the upper RPM tune up that i like....
right now everything is safe but it just seems like the gas milage is plain horrible..... its like i can go for a 20 min drive and being easy on the pedal and suck down 1/2 a tank before i know it.... or it could be the new fuel sensor needs to be calibrated :shrug:
i'd still like it to idle at 14.4 AFR..... and its still not making any sense why it gives me a number above 1.0 when i can see the LM1 reading 13.x... it should be giving a .9x number....
