Best way to tune spark table
Timing can be changed all over the driving map. if you take a look at a timing table you will see why, there are tons of cells in the timing tables.
If you are on a budget you can use the method to get close but you are going to be well down on power unless you hit the dyno.
Based on my experience. Id just get fueling right and go to a dyno. Budget for around 2-3hrs min and solely concentrate on your HO table.
Ive just made a whole lot of changes myself and Im not even going to bother doing anything on spark. Im just going to get fueling sorted and go to the dyno. There is no point wasting time on spark IMO.
