Diagnosis of P0174/P0200.
Old Mar 26, 2007 | 07:57 PM
austexz28's Avatar
Default Diagnosis of P0174/P0200.
I bought my 00 Z28 from a friend who was the second owner. The original owner did all the work to the car or had it done at MTI. I know that it was tuned by MTI and so I'm guessing the full LS1 edit. That was about 4 years ago.
The SES light comes and goes. I was able to finally pull the codes and got this...
P0174 - System to Lean (Bank2)
P0200 - Injector Circuit Malfunction
It was suggested that might be an O2 sensor problem, but I obviously don't know for sure or I wouldn't be posting.
All .02 appreciated
Old Mar 26, 2007 | 08:15 PM
slammedchevy's Avatar
i left 1 injector unplugged and it threw a p0200 code
Old Mar 27, 2007 | 08:28 AM
austexz28's Avatar
The car hasn't been "touched" in over 2 1/2 years and in that time it has only had about 5, oooo miles put on it. Surely, hopefully, an injector isn't going bad?????? Occasionally it will want to idle at about 1100-1200 rpms, usual is 900...
Old Mar 27, 2007 | 08:32 AM
foff667's Avatar
LS1TECH Sponsor
sounds like an injector issue hence the p0200 code...the system lean code just backs that other one up...if an injector isnt firing correctly it could cause a lean condition on that bank.
Old Mar 27, 2007 | 09:24 PM
austexz28's Avatar
After pulling my head out of my *** with a little help, i think that the answer may have been the obvious. The car sat lots during winter, gas goes crappy which is no good for injectors. Sounds like it is time to blow the soot out!!!
