SD tune: SES code normal?
PCM-
P0102 HC
P0103 HC
Is that normal? Thanks!
From the Internet:
"A code P0103 may mean that one or more of the following has happened:
The MAF may be disconnected, or a wiring connection may be bad
The MAF sensor may be damaged "
"A code P0102 may mean that one or more of the following has happened:
The MAF may be dirty or otherwise contaminated (Note: if you use a reusable oiled air filter, be careful not to apply too much oil or that can contaminate the MAF).
The MAF sensor may be faulty"
"Note: You can also set the MAF Sensor Failure Frequency to 0 in the PCM to enable SD mode. Whichever method you choose, you will throw at least one code and set the SES light. You can disable the SES light in the PCM for the corresponding codes, or just ignore it."
