wow! wft no start/ no crank.... i have 1 code. PLEASE HELP.
Old Apr 11, 2007 | 09:37 PM
KILLER-LS1's Avatar
Default wow! wft no start/ no crank.... i have 1 code. PLEASE HELP.
hey i was driving around all day today, and when i was driving home from school, my a pillar gauges and stock gauges stopped working. well i got home turned the car off, and then when i tried to start it up, there was NOTHING. no crank at all. i know the altenator and battery is good. i checked EVERY fuse. i checked for codes and got p0650. its a malfunction indicator lamp circuit malfunction. please help with this. i have no idea why it isnt running.... oh and everything else electrical works in the car.......
Old Apr 12, 2007 | 01:54 AM
KILLER-LS1's Avatar
oh and i switched the starter relay with the headlight relay and it still wouldnt work... any ideas?
Old Apr 12, 2007 | 02:08 AM
koolaid_kid's Avatar
From the web:
"Check all your relays and fuses for good contact. All it takes is a loose fuse to cause all kinds of grief."
"Ok, I checked and a couple of fuses in the eng box were not completely seated. Took PWR off the car and I'll see how she behaves...It's been a few days and it hasn't acted up. I like the simple fixes!"
When you say that you checked every fuse, did you visually inspect (not so good) or did you pull each one and test for continuity with an Ohmmeter (good)?
Somewhere you have an open circuit, most likely a blown fuse (the easiest fix, IMO).
Old Apr 12, 2007 | 03:05 AM
KILLER-LS1's Avatar
ya i literally pulled every one of them out and used a fuse (continuity) tester. im just drawing a blank on what else to do....
Old Apr 12, 2007 | 04:14 PM
98_blk_Hawk's Avatar
If the gauges fuse is blow or pulled whille car is running it will keep running but will not start or crank after the key is turned off. The gauges fuse made me invent a few new fourletter words a few months ago. I would start there.
Old Mar 9, 2010 | 07:38 PM
SuperC1's Avatar
Hate to bring up the dead, but I may used a couple of those four letter words you made up, how did you get it to start again once the fuse was replaced?
Old Mar 10, 2010 | 12:24 AM
KILLER-LS1's Avatar
i just put a new "gauges" fuse in and started right up. make sure your security light isnt blinking while trying to start your car....
