ABS and Brake lites
Well you were rite about that. I took it to AutoZone and there were no codes present and he couldn't reset the ABS/BRAKES lites either.Well time to pull the fuses and turn it on and **** it off. Damn i just about had it relearned too just when you think got it whipped. I'll make sure this week about the pluggins at the ABS sensor. My car has 3 Channel abs and it should be on the carrier housing.
I used to work at Bosch in the braking division doing software, though the f-body developement was ending when I started in 98. I don't have much time know, but I will reply more later on items to check.
If the lamps are controlled by a communication message, it will not be possible to turn off electrically without building a "delete" box to send the proper messages. It is not possible to reprogram the ECU though as they are masked ROM parts.
If the lamps are hard wired to the ABS ECU, it should be fairly simple to wire in a simple fix.
I will try to check into it tonight, but it will most likely be tomorrow with the schedule for today.
