2 bar SD HPT what basic stuff do I change to get the car to run...
Old Apr 18, 2007 | 06:01 PM
Mark98SS's Avatar
Default 2 bar SD HPT what basic stuff do I change to get the car to run...
...well enough to get it on the trailer & to my tuner? It's a 98 SS stock bottom end, mild cam, D1SC at 7 psi. It's been tuned on the MAF but need to get this done. I have the GM MAP sensor # 12580698 to install & then will write the PCM to 2 bar in HPT v2.1.18,. Any guidance appreciated.
Old Apr 18, 2007 | 07:55 PM
foff667's Avatar
LS1TECH Sponsor
you'll need to at minimum setup a starter VE table as described in the flash demo within the help file. Depending on the cam you might need to even tweak that, idle, & spark. Then just unplug your maf & you should be good to go.
Old Apr 19, 2007 | 05:44 AM
Mark98SS's Avatar
Thanks, I'll get that set up in a new .bin before I install the MAP sensor & flash the PCM before I try to run the car.
