Restting trims without a scan tool?
Old Apr 21, 2007 | 05:01 PM
fil131's Avatar
Exclamation Restting trims without a scan tool?
1. I know I can leave the battery +and- for a while and wait for the system to drain, is there any way to make it drain faster?
2. Ive heard touching the positive and negative cables together without the battery attached will drain it faster, kinda like a capacitor for car stereos.
3. "but my preference would be to discharge the system on an output side of a module ... not the B+ side ...
What happens if you have a circuit that has a capacitor and is preceded by a diode? It won't discharge ... diodes act as electrical "check valves" ...
Use an output from the module to discharge"
This one came from another forum and I was wondering what they might mean by module?
Any ideas.
Until I get my new scanner to reset fuel trims I'm looking for another option.
Thanks Guys
Old Apr 21, 2007 | 05:42 PM
2001NBMZ28's Avatar
This will reset the PCM, including all the readiness tests, idle will be grumpy until it relearns:
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
Old Apr 22, 2007 | 02:11 PM
fil131's Avatar
great advice thanks for the help 2001nbmz28, dont know why I didnt think about that.
Old Apr 23, 2007 | 06:58 PM
fil131's Avatar
well I tried this trick and it didnt work, gonna try it again today, but in the meantime any other ideas?
Old Apr 24, 2007 | 07:41 AM
06MonteSS's Avatar
LS1Tech Sponsor
disconnect the negative battery cable, then step on the brake pedal a few times and turn the headlights on... this will drain any residual power that is left in the system.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Apr 24, 2007 | 08:17 AM
wait4me's Avatar
The trims will reset the second that power is killed from the pcm. If you unplug the connector on the pcm it will be reset by the time you screw it back on.
Old Apr 24, 2007 | 08:32 AM
06MonteSS's Avatar
LS1Tech Sponsor
I would still disconnect the battery cable too though, so nothing arcs when disconnecting or re-connecting the PCM power/plug and have it get zapped.....
__________________
Old Apr 25, 2007 | 01:14 AM
fil131's Avatar
coo thanks guys, I of course will not do this anymore when I get my new scan tools. But for the time being, this is great.
