My car won't except my ported tb?
I just bought a ported tb and my car now idles between 1500 and 2000 rpms till i come to a stop. When i get to a stop it is still about 100 - 200 rpms to high. So i put my stock tb in and all is well again. Problem is my car was tuned with the ported one on it and I would like to make that tb work. How do i get the ported tb to work?
It sounds like the TB is ported a little too much around the TB blade.
Here's a simple check for you:
- Take new ported TB and hold it up to a light
- If you see some or alot of light around the TB blade and TB housing, the TB was ported to much
If it's ported too much you can either take a chance and fill in the low spots with JB Weld and sand down till it's stock like or start over with a new TB.
I'd vote for starting over with a new TB since I wouldn't trust the JB Weld, you never know if it would ever come off and go into the engine.
Bill
Bill
I noticed the ported tb has a second hole drilled in the top side of the blade is that probably the problem? i held it up to sunlight it seems to be flush the whole way around the blade. I wonder if just taking the blade off of my stock tb and swapping it over to my ported one if that will fix the problem.
