battery change = all problems solved??
Old May 3, 2007 | 10:11 PM
Transamman02's Avatar
Default battery change = all problems solved??
My battery was around 5 years old..and the shop that tuned it recommended i change it..i waited until it completely died last week to change it and was astonished at what had happened. I had recently got my car inspected and threw 7 codes (po101, po102,po106,po135,po410,po502,p1133)..i have always had a check engine light until i installed my new battery. Ive been driving now for a couple of weeks and still no light..idk i just thought it was kinda strange and figured I'd let some of you guys know..maybe it will work for others lol
Old May 3, 2007 | 10:35 PM
SLP4CamaroSS's Avatar
all it did was reset the code if you had a problem it should come back once yoru computer see somethign wrong to throw the light again
92slowmaro's Avatar
what are those codes in reference to? i know the gm system doesnt run correctly if your under 9 volts or it shouldnt even start if its under 9 volts.
Old May 4, 2007 | 12:39 AM
po101 - mass air flow curcuit out of range
po102 - mass air flow curcuit signal low
po106 - pressure circuit out of range
po135 - 02 heater circuit bank1 sensor
po410 - secondary air injection system
po502 - vehicle speed sensor low/no signal
p1133 - insufficent switching
Old May 4, 2007 | 01:30 AM
Mike44138's Avatar
Most of em sound like they could be low voltage related. In order to get the PCM complete all DTCs you could always do a drive cycle, but if you've been regularly driving it for a few weeks I can't imagine you haven't completed one by chance.
