Commanded air fuel ratio Moving
I have been trying to figure out while tuning my MAF why I can’t get the A/F dialed in 100%. I recently installed a cam and have completely redone my tune. SD OL the commanded and actual are right on. I just noticed that with the MAF enabled that the Commanded A/F is moving up and down around 3 to 4 k. COT is disabled OL EQ is set to 1.0 and my EQ ratio VS RPM is set for 1.16. What other table would or can intervene with Commanded AF?
I found the fluctuation while logging AFR VS MAF freq. Any help would be greatly appreciated
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
yes i posted the Config i used and the one of the log's on HPT board. The commanded at WOT is just crazy. i have started over multiple times with the WOT part of the maf table. copy and pasted the error, then the commanded changes and my previous effors are lost.
Originally Posted by SSpdDmon
That may just be PE turning on and off. What is it moving from/to?
Well i started in that direction but my PE is set for 2k
