PE Enable
Old May 8, 2007 | 11:56 AM
99ChargedFRC's Avatar
Default PE Enable
On my 98 and 99 corvettes the PE table is almost always enabled. There appears to be 2 triggers on the PE table, map pressure and TPS. My Map is set to 15KPA, which is all the time, and TPS is: 0-1200RPM=45%, 16-2400=23%, and all above are 19%. This just doesnt make sense to me. Should I increase the RPM to above 3k or raise map? It cant be hurting anything but I am going to have to scale the VE down a lot since the PE is a multiplier. Any info would be great!
Old May 8, 2007 | 12:12 PM
foff667's Avatar
LS1TECH Sponsor
These are just delay's...most stock calibrations you'd ALSO need to be above 65% tps up until around 3000 rpms to enable power enrichment mode.
Old May 8, 2007 | 12:15 PM
SSpdDmon's Avatar
That's a bit aggressive. Download a stock tune and you'll see it was originally 64% up to 2800RPM before falling to 26% at 4400RPM.
Ever car is different. But personally, I like to set NA cars up with a ~50% enable down low and 20~25% up high....usually following the trend of the stock settings.
PE enable is just like the auto trans settings at WOT. You have 2 triggers (kPa and TPS in this case instead of MPH and RPM). Turn one on all of the time (e.g. kPa enable @ 15), then all you have to do is wait for the 2nd trigger.
Old May 8, 2007 | 12:38 PM
Both cars are forced induction, do you think this matters? The actual stcok file looked the same. I see no need in being in PE all the time like that. I practically have to let off the throttle when cruising to get out of PE.
Old May 8, 2007 | 01:08 PM
What do you mean delays? Am I missing something? The enable tables I would think would be the actual triggers. I will post a screeshot real quick and see what you all think.
Old May 8, 2007 | 01:10 PM
Wow... am I stupid I was reading the HOT table. I should be going off the cold table. I feel retarded.... my bad guys.
Old May 8, 2007 | 02:16 PM
SSpdDmon's Avatar
There ya go....
