question about tuning
Old May 17, 2007 | 10:27 PM
fuseone's Avatar
Default question about tuning
what are all the things a shop can do with a dyno tune to you're car?
Old May 17, 2007 | 11:02 PM
fuseone's Avatar
Old May 18, 2007 | 06:16 AM
RedWS6 00's Avatar
Would be best to ask the shop to see what they say they do.
They could do many things, its all down to the shop.
personally I would invest the time in learning to tune yourself, then you can do it as often as you like for every mod you do.
I dont think anyone could give a reliastic list of what a certain dyno shop can do. Tweak IFR, getting the WOT fueling correct. You would need a few logs on the streeet to get the VE correct, which a shop probably wouldn't do.
"what are all the things a shop can do with a dyno tune to you're car?"
one thing could be, blew your engine and say it was already like that.
Old May 18, 2007 | 07:35 AM
crainholio's Avatar
35 minutes later:
To answer the question precisely, a shop can't do a thing with a dyno tune to my car.
Now, if you were to ask what a shop could do for the car you have, that might be different. They can bend a pushrod, spin a bearing, tune the VE table to match your mods, etc.
Old May 18, 2007 | 10:08 AM
fuseone's Avatar
ok then explain how ther gonna bend a pushrod or spin a bearing
Old May 18, 2007 | 10:13 AM
crainholio's Avatar
I didn't say they were "gonna", I said they "can."
Old May 18, 2007 | 10:59 AM
ZL1Killa's Avatar
put your car on the dyno...floor it...keep floooring it....
all shops will say they will do different things, hell i bet if you call the same shop twice or more they will say different things as it will never be said the same twice.
a dyno tune, involves getting WOT fueling right for peak power and torque.
most shops also do street tune after dyno tune to make sure everything is ok daily driving... get fuel trims in line...and make sure no KR on the street going WOT.
does that answer your question?
