Help! Car running very lean!
http://www.u.arizona.edu/~jtnelson/chart.jpg
I pulled the IAT module out after the dyno runs so it would richen up but I'm wondering if there's anything else I can do.
1) Did you open the cutout just prior to the dyno runs?
2) Do you have a completely stock MAF or has it been modified?
3) Are there any other modifications not listed?
Assuming the PCM has had time to correct the LTrims I would not expect the A/F ratio to be that lean.
Tim
on there? Fooling IAT is supposed to add spark advance,
Dunno about mixture though. Not clear on whether you
had in in place during the pulls, if so, it's a suspect
(along with way-lean mixture) in the pinging.
Kind of baffling why you look nice and fat down at 3KRPM
but go way downhill later.
