Need some help Tuning my Converter
Old May 19, 2007 | 08:47 AM
Pro Mouse's Avatar
Question Need some help Tuning my Converter
Ok I have a Yank SS3800 ,How do I want to set lock up mph to tps%?Generally how much higher do I need to set the TC apply over mph at a given tps%?Say I am in 3rd gear going to 4th at 12.5% TPS my mph at 36 where should my tc lock ? Thanks for the Help
Old May 19, 2007 | 02:00 PM
jimmyblue's Avatar
Moderator
Start off with looking for the onset of TCC slip in normal
driving. If the clutch isn't holding then unlock it at that
TPS/MPH so you don't scrub it to death. Conversely look
for where you'd prefer it to unlock and hit powerband for
you even if it's holding.
I don't think there's any big difference between converters
in the performance sense here but clutch torque capacity
and slip-at-load durability sure do vary.
I like the 4th gear lockup to be a couple or three MPH above
the shiftpoint MPH at low pedal. What you want to do for high
pedal lockup, I dunno.
Old May 28, 2007 | 09:18 PM
Pro Mouse's Avatar
Thanks for the info Jimmyblue ,will get back on this topic after my tuner gets it running right on the Dyno and WB...
