Startup is very lean, 19.2 on W/B
Old May 22, 2007 | 07:32 PM
Blown Interceptor's Avatar
Default Startup is very lean, 19.2 on W/B
I adjust the idle airflow vs coolant temp a while ago, could this be why I am so lean?
Here is where I set it.
Attached Thumbnails Startup is very lean, 19.2 on W/B-mvc-110f.jpg
Old May 22, 2007 | 08:14 PM
Violatorno1's Avatar
What type of WB? Is it just when you first fire it? I'm using an LC-1 hooked to EFILive. When you first fire the car the WB needs to heat up and set. While this is happening the Innovate software reads "Warming up" on the guage and the readiness light flashes. During this time my A/F reads 19-20.1 until the WB warms and the light goes solid. I'm sure this would be the same for any WB.
Old May 22, 2007 | 08:29 PM
It's an LC-1 w/gauge. Yeah, goes down to around 14.7 when the car warms up. Sounds normal...
Thanks
Old May 22, 2007 | 09:16 PM
SSpdDmon's Avatar
It's probably the AIR pump (assuming you still have it attached). It injects outside air/oxygen into the exhaust on start up.
Old May 22, 2007 | 10:26 PM
ujslost2's Avatar
Yes, lowering the values in the idle airflow will cause it to go leaner. The PCM thinks its getting less air in the motor, therefore less fuel. And vice versa. Try increasing the values some and see what happens.
Old May 23, 2007 | 10:10 AM
SSpdDmon's Avatar
The idle airflow values have nothing to do with fueling. It's just a starting point to find the correct airflow for idle. The STIT's and LTIT's will keep it where it needs to be airflow wise assuming they're not maxed out because of inaccurate information in the base airflow table.
Fueling needs to be adjusted in the fueling tables.
Again, this issue is most likely the AIR pump skewing the WBO2 data. Depending on the year, the AIR pump will operate for up to 3~4 minutes after startup. That fresh air hitting the WBO2 will appear as a lean AFR.
Old May 23, 2007 | 12:33 PM
brad8266's Avatar
