Help tuning w/MAFT
Old Apr 28, 2003 | 11:43 PM
ReactiveSS's Avatar
Default Help tuning w/MAFT
I have worked on this for about 3 weeks now and I feel my base is near perfect. My Ltrim are at an average of -0.9, thats with the MAFT set at +15. Now for my WOT I'm getting O2's with values from 860mv to 890mv for a average depending on how I sort the data. Its at 860mv if I look for only cell #22, its 872mv looking for cell #22 but TPS greater than 4.4 and its 890mv looking for only TPS greater than 4.4. The MAFT is set at zero for WOT at this time so whats the verdict? Thanks and as you can see I learn just slower than most.
Old Apr 28, 2003 | 11:51 PM
felton316's Avatar
Default Re: Help tuning w/MAFT
Are you getting any Knock retard?
Old Apr 29, 2003 | 12:10 AM
JimMueller's Avatar
I'd personally raise the average to low-to-mid 900's. I'd leave it a bit rich until you can adjust it on a wideband dyno.
$0.02
Old Apr 29, 2003 | 12:18 AM
ReactiveSS's Avatar
Very little KR, like only 1.0 degree with timing at 30.00. Sounds high I know but the 2000's seem to pull higher timing.
Old Apr 29, 2003 | 12:16 PM
ReactiveSS's Avatar
Ok I've set the WOT to the number #1 position which should 2% richer. Car felt a bit sluggish so maybe being lean it wasn't as responsive as it should have been. I'll Atap later today and see what the data says. I'm getting there just trying to avoid a hole in the old piston top.
Old Apr 30, 2003 | 10:37 AM
ReactiveSS's Avatar
Update after setting the WOT switch to 2% richer,the 02's now read an average of 891mv. I made two agressive runs and sorted the data from both. Timing is at 30.8 degrees with very little KR. One question would be that my Ltrim have gotten richer -4.3, is this normal or is it due to these both being WOT runs.
Old May 3, 2003 | 03:29 PM
WS6 GreeN's Avatar
If you're getting very little KR, you need to leave it alone. Your A/F is probably near right where ti should be. Just my $0.02. My LTRIMS are around -1 to -5 while cruising.
