on start ..spark help
Old May 25, 2007 | 06:39 PM
otherwhitemeat's Avatar
Default on start ..spark help
old f.a.s.t. sequ. unit......was in the car working last year now a have a no spark condition.... if i ground the white wire from the msd box the coil fires....but the f.a.s.t won't fire the coil.....so which ground pin on the f.a.s.t is the controller of the white wire......also how do i check to see if the f.a.s.t. is getting a good msd crank trigger signal and what are the ohm specs of the magnetic pick-up..........help oh which wire on the msd crank trigger is the ground and negative wire.... thanks
