How do you lean the car out at idle?
-10 to -12. The car smells really rich when your at the back by the exhaust.
Thanks
Since at part throttle you are not rich or lean, the trims are correcting, wonder why you smell gas? Did you change headers or exhaust?
If you don't have LS1 Edit and have a MAF Translator you can lean out the base setting.
As an aside, when you see misfires in Atap with some cars, some of those misfires are due to a car running rich and the plugs are loading up.
I will adjust my IFR table.
Thanks for the help.
overlap, you can "shoot through" some fuel/air while
both valves are open (BDC). At higher RPM you're just
"pipelining" and it's good. At idle you have enough time
to blow through. An exhaust that's doing some resonant
extraction will provide the draw-through.
As indicated by LTFTs of 10-12, the computer is in
control of the average idle mixture (it is not pegged
out at -25 or +25). You could lean it out but there's
a good chance that this won't matter.
A 10% rich natural mixture error will only put you to
about 13.2-13.4:1 AFR which should not be a killer;
inefficient, yes, but not too bad. At least when you
step off the map for closed loop you'll be in a good
place (slightly rich to cover any lean transients from
throttle etc.).
