bcm and ground locations
Old Jun 4, 2007 | 08:33 PM
nvrstsfd23's Avatar
Default bcm and ground locations
Where is the bcm located and how many grounds and their locations as well on an 02 ta.
Old Jun 4, 2007 | 10:53 PM
fast377's Avatar
The BCM is located under the dash on the passenger side kind of behind the glove compartment. I believe there are two grounds and they hook to the lower dash support bracket on the passenger side.
Old Jun 5, 2007 | 05:19 PM
nvrstsfd23's Avatar
I ment the grounds for the car as well not just the bcm. Like the frame to body ground etc. I don't know where these are or how many to check.
Old Jun 5, 2007 | 05:56 PM
fast377's Avatar
There are several grounds on the car. I believe two on each side lower dash mount, couple on the rear driver side head, few on the pass side block, one or two on driver side of block, and a couple more I can't think of at the momment.
Old Jun 6, 2007 | 01:10 PM
nvrstsfd23's Avatar
So would any one specifically be causing the issues I described.
Old Jun 6, 2007 | 01:47 PM
Frost's Avatar
uhhh you didn't describe any issues.
