Trying to tune MAF
the main idea is that your resulting AFR is going to be a result of VE, MAP, TEMPS, IFR and IPW. VE and TEMPS and IFR are highly nonlinear functions, start mulitplying them together and you have a nonlinear hell. so replacing tuning all this stuff with just IFR or just VE is just silly, because it will never cover all the cases needed to run properly. that's why VE just doesn't converge for a lot of people.
i'm working on a model where we'll be able to tune all these things at the same time. it's not going to be perfect, but it's gonna be better than what we've seen using the AFR% corrections.
I agree here. I believe VE is just a start and a small piece of this complex puzzle which could explain why I see so many VE tables that are smoothed done with VE tuning alone and certain areas seem to suffer with higher/lower BEN's in cells but are accecptable. What it seems I'm finding is that with my larger injectors and H/C package that I needed to use your spreadsheet to get IFR's to where the engine liked and it started and ran fine. Then started AutoVE and as I smoothed the table I noticed certain KPA rows that needed tweaking but would really put a good wave in the table. My thought now is to adjust the IFR table in those KPA ranges in small increments to bring BEN's closer. Sorta tweaking the IFR table like VE needs to be tweaked. I believe this will bring BENs closer but there will still be the issue of temps and PW's to deal with. "One step at a time."
If I seem off the wall here at all, please inform me. I'm just a novoice compared to ALOT of you who's just on a learning curve.
). My AFR was spot on. Once I started getting stuck in lights downtown, heatsoak set in and my car leaned out.I think we notice it more often in the summer months because things get warmer under the hood a little easier when it's not 55* outside. I honestly believe if we could relocate the IAT to a better, still accurate place not subject to heatsoak, it'd be the solution (like maybe mounting it somewhere in the front bumper so that it hangs in the air - maybe secure with some fishing line or sometihng).
If so then everything calculed by temps would be skewed such as injector tables and VE, ect....
gotta remember few things tho:
the fact you don't see it, doesn't mean it's not there. there's plenty of tables that get used but we dont get to know even exist, see, yet alone alter.
same goes for the inverse. the fact that something's there, doesnt mean it gets used. like cylinder volume in e40 pcm's, it's there, but it's useless.
labels are misleading. some tables are not used as the label might indicate, others are just plain wrong. OLFA==open loop fuel ADDER? adder my ***, it's a divider.
so with all that said, simple models are fun to play with, but they should really be used for building deeper understanding. you can just use TEMP=IAT for your model, and simulate what kind of fueling decisions it would make. how off would it be? is it better on average? but how bad are the really bad mistakes? after all it only takes few bad fueling decisions to blow **** up. which way does it err? rich might not be good at it, but lean is far more likely to blow it up, so you want to see 'tendencies' of your model.
then make another model, TEMP=IAT+(IAT+ECT)/2 and do the same for that model, compare results, errors, rinse repeat...
explain please
-edit-
unless you mean (not trying to be obvious but...) it's in EQ format where 14.7ish / 1.30 = 11.3:1 ..... but the 1.3 could be considered additive I suppose since that extra .3 over 1 is against stoich right?
well i guess if internally it's stored as .3 while we see 1.3 then it it is an adder. i guess that's another good point: what you see is not necessarily how it really works.
Again your AIM is for AF ratios that are not real. IF you try to rationalize the amount of air actually in the cylinder and the amount of fuel in the cylinder then compare that to the AF your observing you will find a large error between the 2.
I have no idea what your observing but its seems very inverted. How are you concluding with rich down low ? Higher MAP values at low rpm should always be richer then lower map values. the engine is more heavily loaded.
Well then, explain why this approach yields such excellent results as far as real-world driving is concerned if it's so wrong... I've seen too many cars come out running like a champ to beleive that there is some large flaw here
I have no idea what your observing but its seems very inverted. How are you concluding with rich down low ? Higher MAP values at low rpm should always be richer then lower map values. the engine is more heavily loaded. while I tend to agree, the big issue is that the lack of low-end vacuum puts the PCM into an area around idle where the perceived load is much greater than the actual load, which results in overfueling
I'm still trying to understand how unburnt O2 is making it's way into the exhaust because of my cam overlap.?.?.? What kind of pressure scenario would allow for a stream of unused intake air to make it into the exhaust stream? I mean...the piston is either pushing exhaust gas out or pulling fresh air in, right? And, both valves are closed at TDC, right? So, where does it get by? Not only that, but why would it proportionally vary based on RPM if the amount of overlap doesn't change (re: "Most cams usually 'cleanup' above 3000rpms)? Just trying to visualize it and I can't seem to see it in my head...
think of it like this.
If there is an exhuast pulse going down the exhuast system when a cylinder is in an overlap state that creates vacum in the adjacent header tube. That vacum and pull " much larger swing at low engine speeds" will actually suck fresh charge out of that cylinder.
Hence your oxygen wash.
It happens it exists and its real. Watch a header tube during the intake stroke and you can see the tube temp drop 40-50 degree from waste 0xygen hitting the pipe.
you can also quantify this by doing simple calculations based on Engine speed and airflow into the engine. You can see clearly it is overscavenging at low speeds.
