Hp tuner questions..
Old Jun 8, 2007 | 10:15 AM
MY99TAWS6's Avatar
Default Hp tuner questions..
Just ordered hptuner the better one so can log my wideband and stuff for my twin turbo project.
Wondering does hp tuners have two step or stutterbox launch capability?Does it have antilag? Does it control nitrous like window switch options. ?
My 97 talon software can do all this stuff so was hoping hptuners can.I guess if it can't then it could mabye be added to it later. I see it can do speed density .The two step is a really usefull thing to have with stick turbo car. Antilag is more useful on big turbo small engine cars to help them spool up and leave the line with big boost.
Oh also have no lift to shift on my talon software another great feature.
And can make the check engine light a knock light or lots of other lights.
Old Jun 8, 2007 | 10:59 AM
Kryckter's Avatar
HPTuners cant do most of that stuff you mentioned. I know for sure it cant do 2-Step and window switch. As for antilag and no lift to shift, I think its pretty safe to say no.
Old Jun 8, 2007 | 11:20 AM
LS1curious's Avatar
A4 or M6
Old Jun 8, 2007 | 01:45 PM
MY99TAWS6's Avatar
m6 currently. I would hope they at least add the two step that should be easy and so would nitrous window switch stuff. Anitlag is not needed too bad on the v8s but could be handy for guys running the really big snails.
They can always update the software so you never know. Guess enough turbo guys just need to keep asking for it to make it happen.
Old Jun 9, 2007 | 12:50 AM
horist's Avatar
Out of the box , no two step (though if M6 I've never played with the limiter tables)
Nitrous window switch: Yes, you can use the outputs to control a relay, the outputs are ground signals that are customizable via boolean statements (RPM > 3000 AND RPM < 6000 AND TPS = 100% AND KR=0 )
Dunno about anti lag, not familiar with that, outta the box though, it can't, you would need to use triggers (above) to activate your own circuit
Old Jun 9, 2007 | 12:56 AM
horist's Avatar
Nitrous window switch... you can use the outputs pretty easily , just need to define the rules and have a relay that's ground activated provide power to the rest of the system
Two-Step ... using the factory GM code not sure how well this would work... w/an M6 car I think you can have 2 rev limiters, 1 for in gear and one for neutral/park ... you'd have to use these 2 for a 2 step ... however... GMs method of a rev limiter (cutting fuel I believe) isn't something you'd want to use....
To cut spark and fuel it'd have to be a custom OS I think... it's doable... but they need to have a cost benefit analysis for design of a new custom OS
Old Jun 9, 2007 | 01:40 AM
SuperZ's Avatar
BS3 hs a 2 step and more features to it but you gotta spend 2500 for one of those
