Yet another theory on how to tune...
If one scews IFR, then it messes with IDC, right?
As for me, I'm going to stick with tweaking the MAF curve (with the right IFR for my injectors) for the next couple of weeks to see just how close I can get things. There's still an AFR variance with IAT's. I'll probably need to move to COS#5 to deal with that. But, at least now I can keep things a little more consistent when logging with the relocated IAT.
On a side note, it was raining pretty good this morning and I was behind quite a few rooster tails on the highway. I popped the hood when I got to work and there wasn't a drop of water near the IAT - bone dry. So, it looks like I picked a good spot.
I've tried setting the MAF bias VERY low like said the first post but it's given me a fit with bigger cams. I hate to give away methodology and what-not, but for N/A, I move the MAF bias down to 1800-2200 and tune the VE up to about 2K and calibrate the MAF.
Don - what I don't understand is, if you are working the MAF anyway, why not build in the numbers that drive the trims negative there rather than IFR?
Idle Frequencies: Had to add ~3% to keep AFR at 14.5~15:1.
Low TPS (3250~4250Hz): Had to pull 6~8% out of the curve to keep AFR at 14.5~15:1 or it would run too rich.
Moderate TPS (4500~6500Hz): Varies from -4%~4% to maintain stoich AFR.
Heavy/WOT TPS (>6500Hz): Varies from 4%~11% to get commanded AFR to equal WBO2 AFR.
That's a 20% variance! Any reason why?
Formula : IPW*RPM/1200=IDC%
I think we like the PCM to have the right information so we can make it easier to figure things out (i.e. when we're using custom pids) or for future mods, because in theory it should be an easier re-tune.
however, even if IDC will be right, your airmass would be halved too, so all your timing, and any other load based stuff like trans would be wrong.
IFR does matter. it only describes changes in fueling according to MAP changes. if you do a tune only with IFR you basically choose to ignore changes from other factors like temps and RPM. can you honestly tell me that you can tune a car saying that 100kPa MAP will demand the same fueling at 1000RPM and 6000RPM? there's a lot more factors here, that's why VE has both MAP and RPM axis, not just load.
however, even if IDC will be right, your airmass would be halved too, so all your timing, and any other load based stuff like trans would be wrong. .
The PCM should then take the other variables it knows (along with what it knows about injector performance) to calculate fuel delivery. Assuming we can determine the constants around the injector's true performance (true fuel pressure, true injector offset, true flow rate, etc.) for all of the various types of driving, we should be able to eliminate the variables and improve fueling accuracy. The problem is, we don't have that information and all we can do is guess. That's what has me so frustrated...
IPW*RPM/1200=IDC%
