Another tuning question???
Old Jun 19, 2007 | 08:24 AM
TN94Z's Avatar
Default Another tuning question???
After you have your VE tuned, etc...and later on your car starts running richer or leaner, do you have to go back through the same tuning process of unplugging your MAF, etc.... or can you just add/subtract units from the VE table alone?? The reason I ask is because I have been told that my car was dyno tuned and now it runs really lean at idle and part throttle driving. At WOT is stays pretty mucj around 12.7-12.9. Over the past week I added a NX MAF kit which caused me to have to change MAF sensors(the one that was originally on the car was a 3 bolt hole design and the NX MAF ends would not work with it) to a stock type sensor. I have not had a chance to scan the car again to see what difference that made, but I assume that it will make a difference. Thanks
