For those of you using Keyspan USB/Serial adaptor
Old May 6, 2003 | 12:57 PM
Beeler422's Avatar
Back in the staging lane
Default For those of you using Keyspan USB/Serial adaptor
What model do you have and are there any specific settings you had to put it on to make it work with EFILive? Thanks.
Old May 7, 2003 | 02:43 PM
Beeler422's Avatar
Default Re: For those of you using Keyspan USB/Serial adaptor
Anyone? I can't get mine to work.
Old May 7, 2003 | 05:22 PM
red ws6 99's Avatar
I dont have eflive but mine works fine with autotap (well no so good, but thats autotaps fault) and ls1 edit. I have the 4 port version. Make sure you have the latest drivers from keyspan website. Mine would not work with anything with the drivers that came with it. Also set your interrupt and speed setting to "compatibility mode". This is slower (but still much faster than you need to log). Mine works in the high speed non-compatible mode.
Gary
Old May 8, 2003 | 11:26 PM
Beeler422's Avatar
I have just the single port version. I think it's like 19QW or something. Anyone have that one?
Old May 9, 2003 | 08:49 AM
red ws6 99's Avatar
They all use the same hardware and software drivers. You might also check some of your other settings on the usb.
Gary
Old May 9, 2003 | 07:23 PM
Beeler422's Avatar
That's what I need to know. Do you have to change anything on the Keyspan settings and if so, what are they?
