LTFT numbers and o2 numbers
do you have a ported MAF? You cant tune a car by WOT LTRIMS either. You need to get a idea of what they are cruising around. Again you want them slightly negative(0 to -3 range). Mine average from 0 to +4 but im happy with them there
Simple fix would be to pull up the MAF table on edit'
highlight the 3000-6000cells and mult by 110%, then scale down the cells after that untill you hit 100%
example 6000 x 110%, 6100 x 109%, 6200 x 108% on down untill 100% so it levels out the table
i know 6000, 6100, and etc arent the correct mhz's but its just for a general idea what to do
that should bring your LTRIMS to 0 or CLOSE when at cruise rpms
Predator can do this for you - they brought mine down by editing the MAF table. You have to talk to them and let them know what average LTFTs you have.
Why are you sending it back to them? They sent me programs in an e-mail and I downloaded them into my Predator.
ok my LTFT are running about 9.38% going down the road at 60 mph. but my o2 numbers are right at 900 so that should be good. what do i need to do to get these numbers down for LTFT? i have 0% knock retard until i back off is that cool? i was messing with the PE and it screwed up the o2 numbers. i put the stock program back in there to see how it was. my o2 is running OK at about 880 maybe too lean and the LTFT is 7%.
i went to put the tuning they gave me back in and it said some kind of time error or whatever and booted me out. why is this? so it looks like my air fuel is good by the o2 numbers but the LTFT is high. what do i need to do? and would i benefit from any more advanced timing? it just doesnt feel like i have the same amount of response as the first time i did it before i sent it off. and i dont wanna screw anything up on my car. i went back to restore so should i just leave it like that until i can get a new program? that is the stock tune right? and why isnt it going back to the program they gave me? sorry so long! please any comments would help a lot!
Ltrims need to be studied at part throttle. The PCM takes the last LTRIM reading before WOT and thar reading tells the PC to add or not to add fuel. If you LTRIMS are 0 at WOT then it isnt adding any fuel. If they are +0 then its adding fuel. But you need to use the part throttle and cruising ones to tune the car...
If you restored the original tuning, you should be alright for easy part throttle driving.
I know some people have taken their cars to Predator and had Predator dyno the car and set it up with a great tune. At least then, you have a good baseline for them to tweak if you do more mods later.
I have had the problems with the error on the screen before trying to load a program also - I just back out and try again - it will eventually go through.
I had trouble getting my PC to load files to the Predator also. Had to set up my BIOS correctly for the port to work.
At least call Predator and find out where you could take it and what it would cost - I'm telling you, if you don't know exactly what you are doing, you can trash an engine in a very short time. Then you'll look like me
.... so when you get your LTFTs to 0 your O2 readings may no longer be at .900 but at least you will have a stable environment to work from
