Need some help
Old Jun 25, 2007 | 12:17 PM
creaper's Avatar
Default Need some help
I just purchased this car this past week. First off it is a 2001 camaro z28 with a procharger on it, full exhaust with o2 sims. I am having a problem with two codes. p0171 and p0174, System Too Lean (Bank 1 and 2). I have looked at the MAF and it is clean as far as i can tell but plan on spraying it with some brake cleaner here soon. Also looked to check for any vacuume leaks but have not found any. I do have the autotap system but unsure what the correct values i need or which ones i need to be looking at. Also has an aftermarket fuel pump that came with the procharger installed and is reading 60 psi, has a boost guage that reads 30psi of vacuume when idle and goes up as i hit the gas, and has a air/fuel guage that stay pegged out on rich. When i first got it the A/F would move around like normal but now it doesnt. Somebody help me out here.
Old Jun 25, 2007 | 01:40 PM
creaper's Avatar
cleaned the MAF and still same problem.
Old Jun 25, 2007 | 02:28 PM
wait4me's Avatar
sounds like you might have a bad fuse for power on the o2s, Or you killed them from running too rich, or the tune is just way off.
Old Jun 25, 2007 | 02:31 PM
creaper's Avatar
where would i find the fuse for the o2's?
Old Jun 25, 2007 | 02:43 PM
2001NBMZ28's Avatar
Just for the heck of it check the ENG SEN fuse - MAF and 02 are on the same circuit.
Old Jun 25, 2007 | 02:56 PM
creaper's Avatar
checked my fuses in the cab and the two boxes under the hood and they are all good. Didn't see a fuse labeled for the O2 sensors though.
Old Jun 26, 2007 | 12:03 PM
creaper's Avatar
anybody else wanna help me out? i already checked all the fuses and none were popped and also checked all the vacuum lines and didn't find any disconnected or loose.
