how do I fatten up PE
I wne to for a wideband dyno today, and was refused because my blower makes too much noise so they are afraid it will blow up on their dyno ??!! thats another subject though. It makes the characteristic ATI chattering and rattling at idle and slightly above idle.
How do I fatten up the PE mode? I have the WOT hot and cold PE set at 65%TPS until 3600 rpm's, then at 60% TPS after that on the WOT PE hot and cold tables.
I guess I was wrong in my thinking that if the Ltrims are good, that the PE will be rich enough.
Can someone please enlighten me as to how to fatten up the PE. I have no wideband in town now if they won't do it, so I am on my own.
Thank you very much for any help
Sam Make the numbers larger to add more fuel.
if you want to be around 12.0:1, the value should be near 1.22 (as an example).
14.7/1.22 = 12.05
If you want richer than that, try 1.25, etc.
I tried fattening it up today, and I think I am getting there. I will mess with it more tomorrow after my emissions test. Hopefully they will not need to get it into PE at the test. I think they do an idle, and a 2500 rpm test.
