Torque Management
My mods are: lid, gears, and thats it.
But in the nexted 2 months i am getting: Headers, Ported T/B, and new plugs and wires.
Should I delete is and what is the outcome of it?
i'm somewhat curious in this area too, i know for torque converters and such, they delete their torque managment, which I need done. But why? and are there any negative side effects to having it deleted?
kinda like... what is it's original purpose, that gm had it put in there.
With any high mileage 4L60E I wouldn't take all of the TM out, just 50% or so tops...
I know the search is slow sometimes, but this one has been discussed a lot.
under certain conditions. Torque Management is performed for the
following reasons:
To prevent overstressing the power train components.
To prevent damage to the vehicle during certain abusive maneuvers.
To reduce engine speed when the IAC is out of the normal operating
range.
The PCM monitors the following sensors and engine parameters to
calculate engine output torque:
Air/Fuel ratio
Mass Air Flow
Manifold Absolute Pressure
Intake Air Temperature
Spark Advance
Engine Speed
Engine Coolant Temperature
A/C Clutch Status
The PCM monitors the torque converter status, the transmission gear
ratio, and the engine speed in order to determine if torque reduction
is required. The PCM retards the spark as appropriate to reduce
engine torque if torque reduction is required. The PCM also shuts
off the fuel to certain injectors to reduce the engine power in the
case of an abusive maneuver.
The following are instances when engine power reduction is likely to
be experienced:
During transmission upshifts and downshifts.
Heavy acceleration from a standing start.
The IAC is out of the normal operating range.
When the driver is performing harsh or abusive maneuvers such as
shifting into gear at high throttle angles or shifting the
transmission from reverse to drive to create a rocking motion.
The driver is unlikely to notice the torque management actions in the
first two instances. The engine power output will be moderate at
full throttle in the other two cases.
The PCM calculates the amount of spark retard necessary to reduce
engine power by the desired amount. The PCM disables the fuel
injectors for cylinders 1, 4, 6, and 7 in the case of an abusive
maneuver.
My specs are: 3.42's, and lid, the car has 42,000 miles on it and its a 00. What would you reduce it to?
