what the heck is up with my VE table?
When the PCM is in open loop, does it even look at the Main VE table or only the backup VE table?
well then, thats a weee bit frustrating, whats the best way to convert the backup VE table back into the main VE table? Can you just copy with labels the Backup over the Main VE to get new values in there and then just manual smooth it out nicely.I realize I should upgrade to a custom OS but I don't have the commercial version of EFILive... yet.
Also, is the backup VE table basically a increased version of the main table, thus being a richer version of the main VE and less resolution?
Just looking at the stock VE vs backup VE. The backup is about 5 points or so lower all around.
As you used to log and change just your primary, keep doing that, but copy the even MAP rows (again, columns in EFIL?) into the secondary table... rinse and repeat
this is why people tell you to keep your VE smooth; resolution running on the secondary is kinda lacking
You can also set your PE tables and do some WOT runs logging BEN's. Since you'll be WOT the A/F will command what you set. Copy/paste those cells the same as you would doing VE 4000rpm and below.
