Idle help- EFIlive
Old Jul 4, 2007 | 12:06 AM
MawneeC5's Avatar
Default Idle help- EFIlive
I took off my procharger and I'm trying to get my cam tuned out. I started with a 98 base tune and have played with everything and cant get the idle right.
When its cold it fires right up and idles fine, but after it warms up a bit the idle will dip to 300 then rev back up to 1800 then settle on 1k. It stays at 1k for a bit then it seems to build up vacum and choke itself. Vacuum will be at 40 after it revs and slowly build up to 90+ at which point the engine chokes up until it revs again or just dies.
Cam is a 221/221 575 112
I've been trawling searches here and on the EFI forums for a couple of days and gotten nowhere =/
Old Jul 4, 2007 | 01:12 AM
Shallow Bay's Avatar
http://forum.efilive.com/showthread.php?t=4661
Old Jul 4, 2007 | 01:22 AM
MawneeC5's Avatar
Wow, great writeup. Thanks!
Old Jul 4, 2007 | 09:11 AM
Doc's Avatar
Doc
With the symptoms you describe I would be looking for a vacuum leak(Hunting idle with MAP building and falling). Just to review, the tune was fine with the procharger, you took it off and put in a cam and now it won't idle? And this is on a 98?
Just to add, you might want to consider upgrading that pcm with your setup.
We just got a 97 vette to idle and drive like butter with MS3, PRC 5.3 heads and LS6 intake. That is until you lay into it.
Get that cam purrfect and slap the procharger back on with COS#5.
Old Jul 4, 2007 | 02:09 PM
MawneeC5's Avatar
I took the procharger off then put in a totally stock tune for a 98..so I"m starting from scratch on getting the cam tuned. I'm thinking its a vacuum leak as well..but cant find anything leaking.
Old Jul 5, 2007 | 08:56 AM
Slowhawk's Avatar
LS1Tech Sponsor
Start by turning the Idle air table up by 15%.
Old Jul 5, 2007 | 09:55 AM
SSpdDmon's Avatar
Or by doing the RAFIG process to dial it in to where it needs to be.
