New heads tuning
I'm EXTREMELY new to tuning, and just got my HPTuners along with an extensive H/C setup that I'm currently building. I did not get new injectors or a wideband setup. I'm aware it will run extremely lean up top until I tune it.
What things need to be changed so I can go full throttle? And how do I get to the injector duty cycle inside HPTuners?
Thanks a bunch guys!
You're trying not to sound like a dick, and I'm trying not to sound like an idiot.
I would buy a wideband but I have $17 in my checking account. And now the car has some massive driveability issues. I'm really upset over this, because I was confident I did everything in the instructions correctly, and now I might need all new valves. I have no money to fix it and I'm going to college in a couple weeks.
Also you may want to post a detailed message with the problems you are experiencing, details about your setup, a copy of the current tune and a couple logs. One idle log from cold using the Idle-Airflow config below and One driving around (part throttle) using the V8-Maf-WBO2 config, try to stay of WOT until the tune is closer to where it needs to be and you have a wb.
My car was idling in a parking lot and I was trying to figure out some tuning stuff. Next thing I know I hear a loud bang followed by repeated slightly quieter bangs. My auto tech instructor feared the cam sprocket came loose and I had bent my valves. I took the valve covers off and a rocker arm bolt had broken, so it's not as bad as it could have been. This means everything is on hold until I get ahold of a new bolt.
