HELP !! GETTING ONE CODE PO654 engine speed output curcuit problem
Old Jul 22, 2007 | 02:31 PM
95transamlt1's Avatar
Default HELP !! GETTING ONE CODE PO654 engine speed output curcuit problem
I Am geting this one code and its stoping my tach on my cluster from working i just got the motor completly rebuilt with all new sensors even the cam sensor and i am getting this one code it says po654 engine speed output curcuit problem .. can anyone help me fix this problem please ... thanks alot
Old Jul 22, 2007 | 05:22 PM
2001NBMZ28's Avatar
'98? www.gearchatter.com/viewtopic8684.php
Old Jul 23, 2007 | 12:55 AM
ya the car is a 98 ta . i read the link you put on there can anyone tell me how to fix this problem cause i really dont get the directions on the link. thanks
Old Jul 23, 2007 | 10:53 AM
2001NBMZ28's Avatar
The first diagnostic, pulling the PCM connector and checking for voltage is easy. You can also visually inspect the white wire going to the C2 Blue connector, pin #35 and see if it's broken - if the car is a M6 maybe it's damaged from a shift light install or something? If you don't feel comfortable with the flow chart or suspect the IPC you might want to have someone look at it for you. Here's a description of all the PCM pins for the '98 - www.ls2.com/boggs/torques/98pinpcm.htm
Old Sep 8, 2007 | 12:23 AM
still need help solving this mystery please help me im going crazy trying to fix my damn tach. .
