ses code?
Old Jul 23, 2007 | 10:04 PM
jomomma's Avatar
Default ses code?
can anyone tell me what the bank one - slow response code means
Old Jul 24, 2007 | 10:19 AM
blade2222's Avatar
bad o2 sensor
Old Jul 24, 2007 | 08:54 PM
jomomma's Avatar
then this will be the third one in four months to go bad. which side is bank one? i had been getting insufficient switching up until this point.
Old Jul 24, 2007 | 09:05 PM
89 formula350's Avatar
"The PCM continuously monitors the Heated Oxygen Sensor (HO2S) activity for 100 seconds. During the monitor period the PCM counts the number of times that the HO2S responds from rich to lean and from lean to rich and adds the amount of time it took to complete all transitions. With this information, the PCM can determine the average time for all transitions. If the average response time is too slow, a DTC sets.
The PCM determines the lean to rich transition when the HO2S voltage changes from less than 300 mV to greater than 600 mV. The PCM determines the rich to lean transition when the HO2S voltage changes from more than 600 mV to less than 300 mV. An HO2S that responds too slowly is most likely defective. Replace the HO2S."
GM service manual
Old Jul 25, 2007 | 09:27 PM
jomomma's Avatar
im just trying to figure out why i keep losing o2 sensors. the car still runs great!
Old Jul 26, 2007 | 07:59 PM
are you running additives?
