Weird Electrical Problem
I just had the motor out of the car after spinning a bearing. The motor is back in and perfectly sounds i now have over 800 miles on it. Took it by the tuner to check everything out. Sitting still in his driveway everything was perfect, checked all sensors, crankshaft pos relearn, balance test came back perfect, evertying is great. When i am driving the car, thats when the issues arise. If i hit a large bump it feels like the car just completely dies, then restarts. It will run like ****, and won't keep an idle. If i turn the key off, then restart everything is fine for a while. I tried to powershift 3rd gear on the highway today on the way to work, and it completely cut-out. It came back on about a second later and i continued to drive.
The 2 grounds on the back of the head were loose, but i tighten them, and still have the same issues.
Also, i have the whine in the stereo at times. My speedometer acts normal under normal driving, but if i got wide open, it;s all over the place, it jumps at least 20-40 mph wide open, as soon as i let out, it goes back to normal.
I'm so tired of cars.
Tomorrow i am going to re-check and clean all the grounds, does anyone else have any suggestion as to what the hell could cause all of this ****?
Any suggestions are appreciated
I've also noticed the speedometer jumps when i rev it sometimes. Seems worse with the ac on.
wow, i completely cleaned the battery terminals, check the grounds, there is a good connection at the alternator(although i didn't remove it to check the connector). And it still does it. Doesn't as bad, but i only went 10 miles. Speedometer jumps all over the place wide open throttle, when i hit some gears most of the lights come on and the service vehicle one stays on until i turn it off. I'm seriously so pissed off with this damn car, i wish someone would steal the damn thing.
I know I'm not the first person to have a problem like this...
Tried another battery today from another car, battery is only 2 months old and it still does the same bullshit.
I just drove it a minute ago at luch. Went through a drive thru, everything was fine. Pull up to a red light, sit for a minute, i get about 10 foot and it lost all power, pushed in the clutch it was barley running, dumped the clutch at 4krpm to avoid the guy behind me from hitting me, go to hit 2nd, lost all power again.
Any suggetions appreciated.
Could is possible be a bad PCM somehow?
Someone told me it could be the alternator, but wouldn't the battery keep it running?
I guess I'm going to throw a fuel pressure gauge on it and observe... Also, i have siwtched in a different fuel pump relay just in case it was a intermittently bad relay. Oh well.
