Open loop A/F ratio adjustment?
Gary
The difference between open and closed loop is:
In open loop control, the sequence of commands in the program is carried out irrespective of the consequences. For example, the PCM sets a fixed type of work to do (the instructions).
In closed loop control, the PCM would set work to do, then monitor the progress to make sure that it is done. If things stop working or don't work correctly then the PCM will act. The PCM observes, obtains feedback and takes appropriate action if the target is not being met. A closed loop system is one that involves feedback to ensure that set conditions are met. In most applications, closed loop happens at approximately 150-160 degrees F.
I don't think you're A/F is the cause. An erratic idle is a tell-tale sign of too much timing. What is your IAC? Start here.
In a no load situation you want your IAC no lower than 30, and no higher than 50. Now put a load on your car, D if automatic, and put the AC on. The values here should be no higher than 120 or so. added- do this check in a closed loop condition
Now try adjusting the timing. Be carefull of adding to much timing - it can give you a great no load idle, but with any kind of load will become erratic. To adjust the timing at idle the base spark tables are the best place. The tables are scaled vs. rpm and g/cyl of airflow. The rpm part is apparent. To calculate the g/cyl use the following formula g/cyl = 15 * MAF(g/sec) / RPM
This formula takes massflow per unit time and converts it to massflow per cylinder. The 15 is a constant which corresponds to a V8 running a 4 cycle combustion cycle. The easiest thing to do is to load your log file into excel, export to CSV, then create a formula in excel which applies the formula above.
Good luck
Any expertness????
Thanks
Open loop in OBD-II engines also use A.I.R, runs I/M 240 tests and makes some adjustment as to what S2 O2s report, you would not want these functional during what what your calling WOT which would be in the PE mode.
Via your PCM scanner, monitor engine loop and clearly once above 122 degrees the engine stays in closed loop, and switches from one mode to another.
O2s work just fine, they are not used, not because they are not good enough but because EPA states true WOT condition (engine at 100% load) is rarely used and is not bound to EPA smog requirements and being O2 values are only read once 1 second by PCM they are ignored and PE tables are used to assure enough fuel is added so Cats are not fried and fuel flow meets engine load demand.
-Gary
