Which Tables to Edit to help with Lockup Issues...
Old May 19, 2003 | 02:44 AM
KYSpeedFreak's Avatar
Default Which Tables to Edit to help with Lockup Issues...
I was reading some earlier posts on working with misfire codes to get rid of my lockup issues with my converter.. I can be going down the road at 55mph with the converter locked, then it will unlock for 5 minutes and then lock again. I have read that you have to edit some of the misfire programming with edit. Can someone tell me which table its under and what values need to be changed...
Thanks in Advance....
Old May 19, 2003 | 11:04 PM
Default Re: Which Tables to Edit to help with Lockup Issues...
ttt
Old May 20, 2003 | 07:09 AM
ttt
anyone?
Old May 20, 2003 | 08:54 AM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
Under the Engine Diagnostic tap, change all the low rpm and idle tables to 32767. I also had to change the med tables as well, you may not have to though.
My husband also put in an additive in the transmission fluid that helped greatly. I believe it is called transmission lube.
I was getting the SES light for the misfires (PO300) and the converter lock and unlock problems made the car very unpleasant to drive. It is totally fixed now
