Tach not working after engine install.
Looks like you may be in luck. Check for vacuum leaks
https://ls1tech.com/forums/generation-iii-internal-engine/539261-ls1-ls6-crank-sensor-trigger-information-request.html
24x and 58x you could have an early ls2
As for the tach you have an interesting case. You state your engine runs but tach doesn't work. And you never touched the wiring to the dash. Did you. all connectors are firmly on the ecm
The tach signal to dash is supplied by the ecm. The ecm gets the signal from the crank wheel. Which others claim will not start if it is the wrong one. But there could be the possibility the car will run at the wrong rpm with the wrong wheel which would need to be calibrated in
I have heard about having to swap the wires in the cam relocation wiring for a LS2 conversion, but I don't remember which wires.
Here's what the wires are anyway:
pins abc are the same as abc for the ls2.
so why are you swapping 12V with the cam signal? Please do post if putting 12V on the cam signal wire works.
The Katech harness is the one that SDPC sells. Don't know why there is still more of these going out its kind of ridiculous.
