SLP Diablo
Old Aug 7, 2007 | 09:16 AM
BlueStreak362's Avatar
Default SLP Diablo
Are these any good? im on a budget but will be eventually camming my car. Also deleting my EGR and cats. I tried a search but couldnt find much. Thanks.
Old Aug 7, 2007 | 09:19 AM
SSpdDmon's Avatar
You can get a mail-order tune from a CMR dealer when you cam the car that can be uploaded through the Predator. However, it's like any other handheld these days - very limited in what you can/can't do - when compared to a full software solution like EFI Live or HPT.
Old Aug 7, 2007 | 11:06 AM
sprayjunkie's Avatar
If this is for an Fbody, I would recommend the standard Predator rather than the SLP unit as the SLP tools have a smaller range of adjustability.
Once you do the cam, take the car to a CMR dealer and they can create a custom tune for you on the dyno to dial in the combo perfectly.
Old Aug 7, 2007 | 11:48 AM
joen's Avatar
long answer, but here i go..........
i have a 1999 SS...mods are LID, K&N filer, smooth bellows, 85 MM MAF, LT's, LM cat back, high flow cats, all SLP stuff, plus I removed the AIR system. I bought SLP's 99-02 predator. Here is my experience so far. When I put in there performance tune my fuel trims were all over the place in closed loop and in WOT. I wanted to tune the trims but SLP's version of this tuner does not have the injector slope parameter to tune the LTFT's. I finally removed my 85 MM MAF and the closed loop trims came back to normal....so the SLP's MAF was a wasted $200. I then tried to adjust the trims for WOT in the PE tables, but they are limted to +/- 5%, not much range. I have contacted both Diablo and SLP on this matter, Diablo has given me a written answer, which I have forwared on to SLP, I am waiting on their response. Basically the story is this, Diablo says that SLP specs out the tuner from them which has limited ranges, and no parameter for tuning LTFT's. SLP says....hmmmm, not sure we do that, I have been waiting for two days now for SLP to get back to me with an answer from their "ENGINEERS". So at this point I would advise you not to buy it from SLP....I'll keep you up to date if your interested.
As far as deleteing codes, you can erase them, but you can not remove them permanently.....
Old Aug 7, 2007 | 01:28 PM
i might just get a HPT.. i have been reading alot and it seems it would be better in the long run plus i have a laptop already.
Old Aug 7, 2007 | 02:17 PM
Keep in mind that you are going from one end of the tuning spectrum to the other now...be sure you are fully aware of what you are getting into with one of the full tuning suites as they do require some more in-depth tuning knowledge.
As for deleting codes, the standard Predator will allow you to delete AIR, EGR and rear O2s.
Thanks
Mike
Old Aug 7, 2007 | 03:04 PM
Yeah, my father is very knowledgeable when it comes to engine tuning, ecm tuning.. etc He was ASE certified and all that good stuff, so he is going to be helping me with that. Im just trying to figure out what will be better for me in the long run.
